stringer template
gazza2007au
im in need of some ideas on making a stringer template guys can someone help me out? i tried measuring every 2 inches it was just all over the place and reuined my main stringer timber so gotta start over again
andgott
Master Chief Petty Officer
Re: stringer template
In the past, I have done it the same way that I would do it when I am working on a wooden boat. I run a piece of string along the length of the boat, parallel with the top of the stringer, then measure the distance down from this to the hull at regular intervals- Usually I use 6" stations. This establishes the curve pretty well, though you might have to 'fine tune' it later.
Hope this makes sense- If not I can post a drawing.
-Andrew
gazza2007au
cheers mate thats pretty much how i was doing it with the tape measure i would like to try another style do u know of anymore ideas?
NoKlu
It's time to read a little. Check out oops! hull extension thread. It's an in depth journal of the complete tear down,chop,and rebuild of a boat.On the first page is an index of the work he's done. Go down till you find building stringers post and scribe method. I would suggest reading the whole thread as it is a great learning tool and a good read as well. Kinda like a book you can't put down.
drewpster
I use tempered hardboard for templates. It comes in 4x8 sheets and is far less expensive than plywood. It also thin and easy to cut. It is much cheaper to screw it up then your ply.
Tempered hardboard is just like pegboard without the holes.
83vert
Have not tried it yet but the post and scribe method seems like the easiest way to go in my opinion. I think a couple of guys here have tried it with success. good luck
chrishayes
yes, post and scribe is the way to go. That or look for Lowkees bayliner thread. He did his a little different but I bet it is easy enough. I will try to explain how I did mine. I have it in my thread but it pissed me off so bad that I didnt take a lot of pictures during it.
First you want to cut your length from transom to bow or wherever they are going. Then, it helps if you left a lip of glass around where your deck used to be so you can sit the timber on top of that then at the transom, i found it helpful to make a piece of 2x4 match the angle of the hull to give you a place to set the timber on at the rear. you can see this in this photo. I also snapped a chalk line where the stringer should be so that I could follow it with the dowel and sharpie described below. I think you can see that too in the photo.
Its the one to the far left. This just sits right up against the transom so on end and gives you the finished height of the top of your stringer. Does that make sense? Then just have someone hold it in place. Take a tape measurer and find the tallest spot along the hull and get a dowel or hammer handle or whatever and tape a sharpie to it perpendicular. You now have to just run the bottom of the dowel along where the stringer is supposed to go with the sharpie against the wood. DO this from stern to bow. Then cut.
Simple if you have patience. I do not.
TojosMojo
yes post and scribe just like you were installing cabinet trim along an uneven wall...
