Hi guys i am new to the site but i have been reading a lot of your posts. I work on cars for a living doing mechanical and body work but i am doing something that i have never done before. I am in the process of a big project here on my 19" renken and i want to make sure i do it right and do it once. I took out the floor from the dash back to the transom and removed all the stringers because they were rotted badly. I am going to use 1" wide wood for the stringers and and 1/2" bc plywood for the layers of the transom. I am finding a lot of conflicting info about what weight and kind of fiberglass to use with the epoxy resin. After I cut the stringers to fit should i wrap them with a real thin layer of epoxy and cloth or is epoxy only good enough. Should i use 1/2" or 3/4" for the floor and should i coat both sides with epoxy and glass and if so what weight. Any help would be greatly appreciated.
