Re: Stress Crack help??
These cracks are caused in most cases by flexing, which may be caused by overstress or weak construction.<br />In order to fix them, you will most likely have to reinforce the area, from beneath mostly, then grind the cracks out and fill, first with resin, then gel coat according to the severity. Match gel coat or paint the whole area.<br />Unless this is a very valuable boat, your pet, part of your family, etc, "fixing" is usually the choice vs repairing.'<br />There are many posts on various sites about stress cracks, search a little and judge for yourself.<br />Good Luck!
