Stratos trailer
jeep99
I just bought use 1997 stratos trailer. The vin number and other identification like tire pressure and weight decal worn out. How and where to get a replacement decal since the manufacturer is no longer in production?
alldodge
Welcome
You cannot get another one but you could probably get one made by a vinyl print shop.
Lou C
No numbers but you can figure out the capacity by inspecting the trailer bearings (#s) and tires. Then weigh the trailer and subtract that from the capacity of the running gear; that will give you the weight it can carry. 5 lug axles are usually 3500 lbs but not always. So it’s important to check.
