NorthStarII
Thread starter- Joined
- May 10, 2010
- 1
I have a twin TAMD71 volvo penta boat with a 24 volt system. I have a stray 14 volts running to ground. When I measure from with steering helm to ground I see 14 volts. When I measure from the negative side of the alternator to the gound on the engine I see 14 volts. Both alternators are working and putting out their normal 28 volts. Needless to says if you are wet and grab the stainless steering wheel and the handrail at the same time you get a pretty good jolt. Any ideas?
