BootMachine
Thread starter- Joined
- Oct 11, 2015
- 8
I think I spun my prop but at first I thought there was something wrong with my motor and now Im totally confused.
1999 Johnson 70 HP 3 Cyl. 2-Stroke
Here are the exact symptoms in order of occurrence:
- Was running at WOT with no issues
- Suddenly power loss similar to running out of fuel but engine was still running slowly at WOT
- Reduced to idle... engine idled fine
- WOT again and still no power to get up on plane... Engine wont rev up.
- Shut everything down and checked what I could on the water.. fuel ok, engine didnt feel hot, could put my hand on the side of the block. It was very warm but not burning hot.
- Started back up and all of a sudden no problem
- Hit WOT again and everything seemed fine and then all of a sudden no thrust and racing RPM. Felt like the prop was slipping or cavitating. Like when it has weeds on it
- Reduced RPM and prop seemed to bite in again
- Slowly increased RPM and prop would slip
- Found the max speed I could go without the prop "slipping" ...or whatever was happening... and made it back to shore.
Ok so to me it seems like I spun the hub of my prop. Most of the symptoms seem exactly like a spun hub.
EXCEPT...
Why did I lose power all of a sudden at WOT and then not have enough power to get back up on plane?
Could I have 2 problems that happened at the exact same time?
Could it be the temp sensor limiting RPM? The engine didn't feel hot and I checked to make sure the water pump was pissing a stream out the side.
Could a spun prob be binding some how? Maybe when the hub let go, rubber came out and bound up the shaft? Just a guess.
Any and all information is welcome especially if you recognize these symptoms.
Thank you kindly...
EXCEPT...
Thank you kindly...
