I have a '93 Johnson v4.
I recently changed the water pump impeller, housing and some gaskets. motor ran fine and tell tail was all working. had a guy check it out who recommended i do the headgaskets. Just finished those, replaced the water deflectors and the exhaust housing gasket. Motor ran fine on the muffs when i tested it, however i just noticed that after leaving the motor tilted down for a while there is this leak of oil out the prop. The only think i can think that it could be is gearbox oil?
Any thoughts on what it is or how to check what's leaking ?
Have attached a pic. This forum has been great so far hopefully someone can help me out here
