Bustedknuckle84
Thread starter- Joined
- Sep 29, 2010
- 421
I have some wiring issues, My lowrance downscan unit reads 6volts and barely turns on when my boat key is not in the on position. However, I confirmed that the +and - wire connections from the unit are getting 12 volts even down to the power source. However when the key is in the on position the unit turns off and has even harder time starting up.
THE CATCH: I moved the wiring to a battery by itself and the unit read and turned on just fine. so its not the unit or the unit's wiring thats messed up.
