paul.larson@usbank.com
Banned
Thread starter- Joined
- Jun 9, 2010
- 1
Hello Forum - I have a 88 force 85. I replaced one of the ignition coils the other day because I couldn't get it to generate spark from any of the the 3 leads coming from the feeder unit. Now, the two leads for the #1 and #2 each will generate a spark from either the #1 or #2 coils, but when both are hooked up, only one fires....... Is this as simple (expensive) as replacing the #1 CDI box?? I did this experiment with all spark plugs removed from the block. As well, the starter is bogged down so, even with the plugs out, the engine was not turning over at proper starting speed.
Any possibility of swapping the two CDI's, given there's an extra lead on the #2? Or is that asking for trouble. . .
Planning to overhaul the starter as well. FYI.
Thanks for any help.
-Paul
-Paul
