Straight up depth finder, what would you buy?
sbklf
Just learned that I can not get a transducer for my Lowrance X65. Want to purchase a new reliable depth finder with a shoot thru hull transducer. Don't want to spend a fortune, any suggestions?
foodfisher
Re: Straight up depth finder, what would you buy?
Straight up would be impractical IMHO:facepalm: Side scan was out of my reach and need. I opted for a gray scale Humminbird. Fit both wants and pocketbook.
Silvertip
Honorary Supreme Mariner
Lots of transducers on E-bay. You need the transducer model number to be sure you get the right one for th X65.
sbklf
Straight up as opposed to a combo unit, not as a technical question (beam spread, angle...). Thanks for the info.
UncleWillie
There are currently 2 available on eBay. HS-WSBK Transducer.
Remember Used =
An item that has been used previously. The item may have some signs of cosmetic wear, but is fully operational and functions as intended. This item may be a floor model or store return that has been used. See the seller?s listing for full details and description of any imperfections.
UncleWillie
If you are looking for a straight Depth Finder, Faria make one with Air and Water Temperature.
