Stock Wakeboard tower
BradBeyer
Does anyone have the stock wakeboard tower from tahoe and have issues with it swaying side to side? I put a picture of my boat with the tower.
Brad
kailec00
Re: Stock Wakeboard tower
I have a tower from Tahoe. It is not like that though. It is black and more slanted. I have no issues with mine swaying side to side. The tower is swaying back and forth? Can you explain more about it, like is it swaying at the top or from where it is attached to the boat?
BradBeyer
It sways from side to side and I believe it is swaying from the connections at the boat. I have the bolts as tight as they go.
I have seen your set up and I like it much better. mine connects on the side of the boat and your connect more on top of the boat.
I am wondering if I put a longer plate on the inside for the 4 bolts from the side connectors if it would stabilize it better.
yourboatmyboat
are the speakers after market?? , they look as if too much weight at the top??
BradBeyer
yeah they are wetsounds but I had the problem before even putting the speakers on
water world
I have installed towers on new boats. Worked for dealer. Make sure mounts should have backing behind them.. I have had new boats that the didn't match up and had to fix. The one i had to fix used 3/4 backing and at least a foot lone. Used marintex to fill voids and hold in place.
dmoss8928
Just a quick question where did you buy your Tahoe wake tower at?
kailec00
Mine came with it on when I purchased the boat. I would think that a tracker dealership could order one from the factory and install it for you. Might want to call one if you have one near you.
TahoeQ4Pilot
My 06 has a factory tower, but it looks like the mounting pads are different. I dont have any real side-to-side sway, but it has some decent backing, too.
