I've got a 454, raw water cooled engine. Water showed up in the oil, so we first looked at the intake manifold. It appeared that the gasket was breached in a few places so we cleaned out the engine replace the gasket, oil filter, etc. and started it up. IMMEDIATELY, water in the crankcase. So...now we're looking to tear down the heads. My question, is that is it likely that the heads or head gaskets are the source of the leak, since the water entered the engine right away? I'm thinking that a cracked in block would allow water in, but more slowly. Here, as soon as be started it up, foam appeared. Also, compression is 175 on all 8 cylinders. Any help or thoughts is appreciated.
