Re: Still thinking about how to run wires...
For a service line into a residence they select a metal for the connectors that is more or less inactive when in contact with aluminum, cadmium if I recall correctly. This is the only place you will find it used. Aluminum has a property called "cold flow" in that it tends to deform when pressure is exerted upon it, and even service wires could stand with a "tightening up" every once in awhile. I would avoid aluminum like the plague on a boat. In fact I would rather use copper for service line too.So what gives when the incoming power to your house uses aluminum wire upstream of the meter and from the meter to your main panel?
Still standard materials for new construction.
Much of the 120v household wiring faulted for fires was due to inadequate terminal torque and or lack of the anti-corrosion grease now used was it not?
