calincoltsdad
Thread starter- Joined
- Jul 17, 2009
- 33
I put a new impeller in the raw pump on my yamaha 4.3L V6 inboard and got alot more water flow to the engine. I have more water flow thru the exhaust and manifolds afterwards so I decided to go to the lake to try it. Anyway the temp still crept up slowly to between 175 and 200 so I went back to dock. I dont have the correct thermostat in but I do have the correct temp. range. Could this be the cause of the overheat? I've already checked all risers, manifolds and lines for obstructions. Can I run without a thermostat to see if the engine will run cooler or will marine engines overheat without a thermostat? I dont know what else to do.
