After cleaning starter yesterday I thought I had Problem fixed Not So, Was on water yesterday started at ramp fine , ran great across the lake fine , shut down to fish a while now is when the problems start. Engine will not start. After setting a while and a couple tries it finally started. After Idling due to no wake zone engine dies. Same thing wate awhile then started up ran great at WOT . Got home and put in a barrel checked spark gap it jumped 7/16 at first but then no spark I had to shorten the gap to 5/16 to regain spark Also no change in starter speed cranking is fine Someone mention Stator? Any Ideas?
Update Im not getting any readings ohms or volts from blue wire coming from stator ?
1995 60 HP Mercury
1995 60 HP Mercury
