Mader12345
Thread starter- Joined
- Mar 13, 2014
- 18
What engine I have and how it performs:
I have a year 2000 125HP mercury outboard. Serial #:0t088785. Since last season, she won't run more than 4500-4600 RPM (engine rated for 5250 RPM, a few years back I would get to 5000). She runs just fine at the speed, great at idle and slow speed (top 2 cylinders). I did rebuild the carbs 2 seasons ago. Rebuild meaning soaked them, pushed a small poker through every orifice, new caskets. There was zero gunk in them.
What I've done to engine in last week:
Replaced all fuel lines and bulb from tank to top carburator. Redid all fittings/barbs. Replaced fuel pump (the entire pump), replaced accelerator pump (the whole pump). Did link and sync per factory manual. Carb plates are wide open at full throttle. Confirmed spark on all spark cables (1/2 gap, blue spark). Reset low speed timing and max timing per manual. Verified compression at 115 PSI for all cylinders (cold start).
Today's lake test:
Started up fine. Idle and low speed fine. bottom carbs kick in and get me to the same 4500-4600 RPM. In other words no change. Then I pulled plugs and sprayed seafoam right into cylinders and also into the carbs. Ran her for a while, no change in performance.
Then I pulled the spark wire on the bottom cylinder and grounded the boot. Then ran her and she topped at 3000 RPM. Replaced spark wire to bottom cylinder and removed spark wire on the 3rd cylinder. Restarted, she topped at 3600 RPM, a 600 RPM difference. As a reminder this engine runs on the top two cylinders till the RPM gets to ~1800 RPM, then the other two join in.
Here's another fact: I ran the engine with the plate that covers the carbs off. I didn't realize you should not do this above 3000 RPM. Too late. But i did find that the engine would get to 5000 RPM that way. I wouldn't call it a stable 5000 RPM. It sometimes dropped to 4700 RPM or so.
Here is a link to a video I took starting at idle and slowly adding throttle until it tops out. Point of clarification in that the throttle can still be pushed forward a few more degrees when it tops at 4500-4600 RPM, but the engine does nothing.
IMG 0911 - YouTube
I haven't checked any electrical except for spark gap test when cranking.
Would love some input.
MArk
Today's lake test:
IMG 0911 - YouTube
MArk
