Stiletto 10323 M1423 to Yamaha F150xa
Ralph2
What thrust washer kit is needed to mount this Stiletto prop to my 2012 F150xa? The motor came with a Solas prop. The existing thrust washer does not allow the Stiletto prop to further into the gear case housing. Also most likely a thicker washer that will accommodate splines (15) may be required so that I can continue to use a castle nut and cotter key? Thanks
Ayuh,..... Welcome Aboard,..... Donno the answer, but yer question deals with the other side of the prop in yer picture,....
What motor did that prop come off from,..??
Have you checked with Stiletto as to whether that prop will fit yer yamaha,..??
Ralph2
Acquired at a garage sale. I understand it was intended for a mercury. Not sure of size. Prop was bought new and not installed. I apologize I did not realize Stiletto was still providing product support. If you have a contact name and number I would appreciate the information. Thanks
