reynold460
- Apr 25, 2008
- 103
have a 1984 mariner 115 hp with the side bowl floats .had the needle and seats replaced and when i would blow air into the fuel inlet (by mouth only) could hardly pop the needle off the seat and the needle and seat are new is this normal being that i know the fuel pump only puts out around 3 lbs of pressure i cant see how the needles arent going to stick does someone have a answer to fix this . . .the reason why i replaced them is the motor would die out and when i would apply very hard pressure to the bulb it would run ok ffor a bit then die down again until the bulb was pressed again the fuel pump is new . i have pretty much narrowed this down to the needle valves after taking this to 3 different boat shops and they were all telling me it was electrical issues to find out after replacing the stator,switch boxes,fuel pump,fuel lines,it was still the same
