Salvador0673
- Jul 23, 2021
- 15
I have a crownline 1997 with a 5.7 mercruiser and an Alpha one gen 2 sterndrive. I was having vibration when I would turn left and right on low Rev. I took the stern off to check the gimbal and the ujoint both were almost new. No water leak. I took the gimbal out to inspect and it was good, however I bough a new one just to be sure. I install the new one. I think I probably use more force with the hammer than I needed. But it did install. I check aligment and it was off by a little bit. In the bottoms no line and the top it had line. I aligned the engine using the aligment tool. Now it has line all around. I crank the engine and did another check and it had line all around. It needed I little more pressure on the tool bar to go in, but it turn 360 fine. My problem is that for 3 days I have been trying to install the sterndrive back and for the life of me I can't do it. The last 2 inches it would not go in. It stop just by the ujoint ring. I have turned the propeller to align the splinters, and nothing helps. The lever is forward. I grease the end of the shift. What is happening. Could I have ruin the cooler? I hammered the gimbal with a 10lbs hammer using the aligment tool. Can dirt fiend its way into the coupler? And if so, how can I clean it without taking the motor out? Please if someone have an idea help me.
