Sterndrive tilt "leak-down" under load
CommanderData
I have a problem where the stern drive "leaks-down" under load (more than 2000 RPM). No external leaks and fluid does not drop over time (2+ years). Anybody has experience with this? Is it more likely that the pump has an internal leak (high-to-low side leak), or the rams?
Thanks.
JustJason
Re: Sterndrive tilt "leak-down" under load
Unfortuneately there is no "more likely" scenario. Unless you want to guess at it you need to get the pressure gauges from merc and hook them up.
