Stern Noise
Superbee
Went out this weekend boat ran great all day Saturday, BUT Sunday After about 20 mins the stern starting making a Load Knocking Noise, I'm new to boats Any Ideas? What to check for? any tests to do?<br />This is an old 1968 Mark Twian boat with a II drive<br /><br />Thanks
Trent
Re: Stern Noise
Check the oil level in the drive and for water.
fendersfender
Re: Stern Noise
loose flywheel will make a knocking sound...i had this problem, took me forever to figure it out (flywheel nuts loose and two broken studs)
Superbee
Re: Stern Noise
I did check the oil level it's full and looks like oil not Milk, the noise is from the back of the boat not inside at all
kwoolard
Re: Stern Noise
sounds like it could be your U-joints. pull the drive, easy job, and check the joints for rust or damage and any sign of water in the U-joints bellow. also may want to check the engine to outdrive alignment.
Superbee
Re: Stern Noise
I was going to pull the drive and check it out but there are no bolts on the back like the new ones<br />Any help here?<br />This is a Old II drive Old i here these are bullet proof drives HHHmmm makes me wonder<br />II Drive 1964-1967 #2008152<br /><br />I can post a pic if ya need one<br />Thanks
kwoolard
Re: Stern Noise
Not sure about that...post a picture. Maybe somebody familair with the older drives will chime in.
Superbee
Re: Stern Noise
Well found out today what is wrong the Pinion Gear is missing a few teeth, well so much for being Bullet Proof:) NOW the Question is Parts Everything is NLA Go figure i have never had a problem getting Parts until today i can't find this Anywhere at all<br />Part i'm looking for 43-39377A3 Here a Pic if anyone has some Parts Contact me<br />Thanks<br />
Superbee
Re: Stern Noise
HHHmmm So everyone gets Dumb when it comes to this old stuff?
Superbee
Re: Stern Noise
there could have been damage when i got the boat but i put about 30 hours on it before Boom<br />Plus other things like a rock between the prop and stern (me) WOT with stern 3/4 up only went 20 mins after that<br />I found the parts i need should have this back up in a couple weeks i hope
