Stern light voltage
mpb536
I'm a complete newborn on this so bear with me. I recently purchased a 2008 Yamaha AR230 and just realized the stern light isn't working. I tested with my volt meter and I get 12v if I put the black probe on the battery ground post and the red probe on the hot lead in the stern light socket. However if I put the black probe on the other lead in the socket I get zero volts. My question is, is this normal? My light won't work when plugged in and I even tried a new light and it didn't work. What could be the issue? All other electrical components on the boat are working properly including bow lights.
sam am I
Yes, it's a normal reading for an open ground at/or to the socket. No, it won't work until you find the open. Chase/follow the ground path from the socket backwards until you find the open. No more "newborn" excuses now.......
mpb536
Damn auto correct. That was supposed to be newbie. Thanks for the help.
