Stereo
Ebshowstock
I just installed a new jbl stereo, speakers and amp. Hooked up power, ground and constant just as the old stereo was. Unit turns on but it blank and the power button on the head unit will not operate or any button on the head unit will not work.
Any ideas why, and what color wire do I use for the remote going to the amp. Blue, or blue and white?
rickryder
Re: Stereo
If it's a new radio it should have a wiring diagram..... Most of them have them on the head unit itself.....if your looking for a trigger wire to fire the amp use power antenna wire..... it goes hot when the radio is turned on. Red wire should be ignition hot....yellow to constant hot 12v and black is ground.
chrclo
Re: Stereo
Blue is usually the amp wire. Most have tags on the wire. Check your wiring for the deck and amp. I wired all my stuff to the battery directly (in a boat this is the best way IMO). Also if you don't have one a second battery is a good idea.
