stereo installation question
badassmofo
I installed just a regular stereo system on my boat. i have a question if any one can help me with will appreciated.
it works fine when the boat is not running but when the boat is running, it cut on and off. ive tried everything and can not figure out. ive tried different ground, ive tried just to install just the stereo into a stand alone battery only with just the stereo hook up to it and still does the same thing when the boat is running. please help and thanks in advance.
5150abf
Re: stereo installation question
Are you sure the stereo is good and the vibration isn't making it cut out.
If you had it hooked to a seperate battery and it still did it I would think it was the stereo, if it is on a totally different power supply not hooked to the engine it can't be the engine.
If it were interferance from the plugs it would just be a buzzing not cut cut completely.
DId you ground this to the boat or a wire in the wiring harness, bopats are different than cars in that they have a closed electrical sytem with no chassis ground like a car has, on a boat all grounds are through a wire.
royal0014
Master Chief Petty Officer
Sounds like something is loose inside the stereo. If you have a regular car stereo, it may not can stand up to the near constant abuse of a boat ride, esp. if it's a cheap Wal-store type. Put down the coin for a 'marine' radio.
Silvertip
Honorary Supreme Mariner
You didn't say what engine make, year, and model you have. The reason this is important is that some engines do not have a voltage regulator and as such, battery voltage can get as high as 16 or 17 volts. Your stereo probably has "over voltage" and "under voltage" cut-off protection so when the voltage gets too high or too low, the radio cuts out. It may be that the charging system is not working properly as well so you are dealing with an under voltage condition. Hook up a voltmeter and see what you have with the engine running (at speed) and engine off.
badassmofo
the stereo is brand new, its a marine stereo. i thought it was the stereo at first then i bought another one so i know its not the stereo. i tried both ground to the metal inside the center console and also tried a wire directly to the battery. there only 3 wires beside the speaker wires to the stereo and i checked all the connection . its a 2001 mercury 90hp salt water and its a 17' center console palm beach boat.
Silvertip
That engine does have a voltage regulator but it may not be functioning. You still need to do the test I indicated. If you don't have a hand-held voltmeter, you can buy them for about 10 bucks at Radio Shack or in the electrical dept of any home improvement store.
badassmofo
but even i run it to a totally seperate battery without anything hook up to the battery besides the stereo?
Lyle29464
I would test it again. remove it from the dash and set it on a pad that will kill the vibration. That wiill tell you if it has something lose inside. Have you tried shaking it with the motor off? You have ruled out high voltage. last thing to look at is static from the engine making it cut out.
