I am installing a Kenwood CD player in my boat and 4 Kicker 6.5" speakers. I also bought a JL audio amp, but not sure I am going to use it until I buy a sub for the boat. The other day I installed the deck, I connected the red and yellow wire to the existing red wire from the boats original stereo wiring harness and the black ground I ran to the ground on the back of the speedometer or tachometer. I turned it on and was curious how it will sound without using the amp, so i hooked one of the speakers up to the wires on the back of the deck. I put in a CD and it played just fine for about 20 minutes or so (even at high volume). Then I removed the CD and put another one with a little more bass. When I was putting in the second CD, the power started going in and out. It will take the CD, but it takes a couple seconds longer with the power going in and out like it is. Once the CD is in, it will try to play but it still is having the power problem and wont read it. I hooked up my Ipod to it and am able to play it at a very low level, but once it gets to volume level 12, I can see the lights on the deck dimming with the beat. And once it gets much higher than that, it cuts out and the power goes in and out again. The boat has been hooked up to a trickle charger so I know the battery is good. I unhooked the + and - battery terminals and hooked them up to my portable power pack (that is fully charged) and got the same results as I did with the battery. Then I hooked the battery up with the power pack and once again, got the same results. What is going on here? Anybody have any ideas?
