Expidia
- Aug 26, 2006
- 2,374
Re: Steering whip around question?
Thx. I see iBoats sells the Teleflex units too. I emailed Teleflex to see if they list a unit for my model. It goes by steering cable length I think but it's under a foot of snow right now. I think they should be able to come up with number of the kit I need.
This probably would not be an issue with a heavy fiberglass rig. I think it's a factor of how light my model is and the 40 hp on it.
It just feels like it's a steering issue to me that once the outboard passes a certain angle there is not enough dampening effect or friction to prevent it from whipping around without holding onto the wheel solidly.
Seems to happen more often when I'm pouring wine from a bottle with one hand and holding my cup with the other hand while doing 35 mph in a slight chop
Just kidding . . .
Exactly. I had a severe jerk to the right and adjusted the trim tab either direction to staighten it up at first. It helped but not enough. Eventually, my steering box gears gave up on me (old boat & had sat forever) and I replaced the box with an AFB one which worked with my old cables fine. Problem solved. If it does slip with antifeedback steering it will only slip a degree and then will lock up. Great Product
Also, If your anti cavitation plate is too big this can cause severe steering probs too. GL
Just kidding . . .
