I have a bit of a problem Im thinking has a simple solution. My steering isnt working as well as Id like it to. I doesn't appear to be power steering or flex cable, I think its a hydraulic mechanical system. As I turn the wheel left, I have to turn steering wheel many many times before getting motor to start turning, not as bad turning right, but bad. Low speed (low load), problem not as bad.
Is there a reservoir to fill steering fluid? Does it sound like Im low on steering fluid? If you look below, Ive circled in orange the two lines that go on each side of the hydraulic piston. Each line has a grease-fitting type port is this where Id fill with fluid, or is this Grease only?
I know this is a stupid question.
