steering locked up
dantheman20
I have a 1994 bayliner Capri. I left for 7 months on deployment and when I came back the steering was completely locked up. Does anyone have any suggestions on where to start to fix my problem?
Bt Doctur
Re: steering locked up
Well, you could let us know the type of engine, and type of steering
dantheman20
It is a 4.3 L mercruiser v6 and im pretty sure the steering is hydraulicly driven because there is a reservoir on the engine. The fluid is full in the reservoir so i dont think that the pump is the issue. The steering does not work with the engine running or turned off.
Bt Doctur
Usually where the steering cable passes thru the guide tube its gets a bit corroded and jams up. Heat and penetrating oil sometimes work.
