steering locked up
wncsmally
I have an older Merc. 85hp 1965-1967 and I have disconnected the steering cable but still can't get but about 3 inch from center to the right and maybe 2 inch to the left.I've greased tube.If anybody has any suggestions I would appreciate them very much.
OBJ
Re: steering locked up
Hi Gordos..<br /><br />Don't mess with it....put a new steering system in it. When they get like that, 9 out of 10 times there is no hope. For safety sake, replace the cable and/or system. The whole system in most cases can be replaced cheaper than just the cable.<br /><br />Jim
D
DJ
Guest
gordos,<br /><br />Does the engine turn freely with the steering disconnected?<br /><br />If so, it's the cable-like OutboardJim said: DON"T MESS WITH IT. Replace the cable. Once they rust inside and lock up, they're dangerous.
You state that you disconnected the cable..?? If it's the swiveltube that's binding, Keep greaseing,+ oiling,+ swiveling... you May have to get abit Forseful... It Should come free after awhile... they usaully bind at the Lower bushing.. you might try putting Oil in your greasegun.. abit messy, But a good way to "power oil" it... To pull the swiveltube apart is a Major teardown....Powerhead has to come off,Etc.... IF it frees up, your good to go.. if not, Dig out the wrenches,+ Shopmanual....
