Steering Issue
Keepdry
I just bought a 1986 Bayliner cuddy w/ 125 Force outboard and having problems with it turning to the right, not bad, just a constant pull. I have the exhaust port slid completely to the left correcting alot of the issue. After a closer inspection, I believe that the fin on the gearcase is slightly bent. Would this affect the steering? Is there anyway to straighten the fin, either by filing or heating and hammering it straight?
Thanks for any help.
jerryjerry05
Re: Steering Issue
Looking at the back of the boat.The trim fin(if pulling right) should be turned to the right.
The skeg can be bent back.I use a 3# hammer and a block of wood, depending on how bad it's bent. Post a pic.J
Keepdry
Re: Steering Issue
Thanks, your correct about the fin being to the right, I was looking from a different direction. Should I use heat.
jerryjerry05
Re: Steering Issue
Not unless you plan on changing the fluid.You can do BIG damage by using too much heat.I never use heat to straighten them unless the housing is empty.
A hammer and block is all you need.Post a pic.J
capri1600
Re: Steering Issue
No heat. Be careful when you start banging on the skeg as that fin is called. Bend it back a little at a time. Don't try to beat it back in one shot with a sledge.
shaun77
Re: Steering Issue
Does it have power steering? I thought this was normal with just cable steering cause of prop pitch?
