Steering Cable
sYnOnYx
Hey Guys,
I have a 1978 Merc 1400 / 140HP
This morning I went to go move the steering wheel and it's seized, why I didn't check this when I got the boat is beyond me.
Can anyone link me to the correct cable I need? Possibly the the steering wheel and anything else I might need to replace the steering wheel assembly and cable.
Thanks in advance.
sYnOnYx
Re: Steering Cable
Can't find the part numbers for the Throttle and Gear cables either.... Odd
Jeep Man
Re: Steering Cable
Hey Guys,
Thanks in advance.
You might want to google Teleflex. Before doing this though, disconnect the cable from the motor to see if the problem is in the cable/steering assembly or with the motor bracket.
100333624
Re: Steering Cable
It could just be a dry clogged cable... I had the exact same issue last week except mine was very stiff and not seized... I removed the steering assembly, pulled the cable off the motor and helm which revealed lots of dirt and no grease at all... I then sprayed some WD40 (or your choice of lubricating spray) into the cable opening, played it about 30 or 40 times back and forth, and let it hang off the ceiling in my garage so that the WD40 makes its way through the cable... I also opened up the helm and will be replacing the grease in there tomorrow... Cable was very dry, now moves very freely! Saved myself over $200 in new steering, maybe you could give this a try and see if it works for you?
Re: Steering Cable
Throttle and shift cables are standard Merc ones, made by teleflex and others. Very common
