Steering bracket
Dkmrocks112
New to the forum here so looking to broaden my knowledge base. I currently own a 1989 tracker 1800fs with a Johnson evinrude 110. I bought the boat last year at the end of the season and only had it out a few dozen times. Getting it ready for the season and i noticed a broken bracket that holds the ram for the steering on to the transom mount. Ive been trying to do some research to locate what it is so i can try to purchase one but am having no luck. If anyone can lend a hand it would be appreciated. The pictures attached have the bracket circled and where it mounts has the arrow pointing to it. Thanks again
GA_Boater
Welcome aboard.
While this is steering related, the busted part is for the motor. So moved this into the Johnson/Evinrude section for more eyes on it.
oldboat1
I think the tilt tube on that model goes through the stern brackets — can’t quite tell from the pics what you have there.
You may need to go to one of the clamps that mounts to the transom (Garelick?)
Honorary Supreme Mariner
I think this is on the kit for dual steering cables.---Often installed as a safety feature on " high speed " boats.
Dkmrocks112
Attached is a better angle from the side. So this may be a bracket from a dual cable steer kit. One thing I noticed is that when turning the motor I get wheel turns to the one side than the other 1.5 compared to 2.5
Yes , as suspected that is the duel cable set up.-----Parts for that can be found on the accessories pages.---Should be an easy fix.
