FunInDuhSun
- Apr 25, 2010
- 507
I’ve used this tank for 15 years. It has always worked fine with my 25HP Evinrude. This spring it wouldn’t feed gas at all, so I removed the line from the tank. It tested just fine, pumping gas thru the squeeze bulb like it should.
I don’t see a way to access the pickup inside the tank because it seems to be welded. I blew a bit of compressed air into the nipple and re-connected the line. When I pumped the bulb, gas flowed for about 3 seconds and stopped. I believe something is obstructing the pickup but I can’t see it. For some reason I can’t post an image….
Is this tank done? Any thoughts?
