Stearing wheel
SSMINNOWVA
Im looking to replace the stearing wheel on my 1960 duracraft, but im not sure if i need any certin information on it, ive seen several i like ,but i dont want to order one sence im not sure if all wheels are basicly the same in fit. Can any one help me on this.
1980Galaxy
Re: Stearing wheel
i think they are all basically the same with one big lug nut in the middle
JimS123
Re: Stearing wheel
Is it an old style cable/pully system or a newer single cable? The older ones are not all the same.
Just take off the existing wheel and measure the hole. Tapered, keyway or splined? Then order the same size.
starcraftkid
Re: Stearing wheel
I've seen several types of steering wheels over the years, most are tapered 3/4" with a keyway, but Mercruiser had some with square shafts, and I've run into a few straight keyed shafts and one with a roll pin which sat just below the wheel which fit into the lower aluminum casting of the wheel itself.
I'd say 90% out there though are 3/4" tapered shaft style.
