Steam coming from tell tale
terrymason
Hello everyone - my first post here.
I have a Mercury 2003 150 XL SWB that has devloped a problem. When I first start it up a steady stream of water comes out of the tell tale in the back of the engine. As soon as I get underway (and it comes up to temp) the stream stops, and only steam comes out of the tell tale. Stopping, and allowing the engine to cool with make water again come out of the tell tale until it gets up to temp.
Some history about the engine:
It's got about 10-20 hours on it since I had the impeller replaced by the local marina.
I'm embarrassed to say that I never flushed the engine until last weekend. I found the garden hose connection on the back of the engine (after referring to my manual), and opened it up to find a good amount of black (oil?) sand in there. I blew quite a bit of sand and grit out of the engine (didn't fix my problem though).
Any ideas or tips? If I need to buy a water pump kit, can anyone point me to a complete kit?
Thanks
Chris1956
Honorary Supreme Mariner
Re: Steam coming from tell tale
Remove the thermostats and poppit valve and see if they are clean and in working order. Drop the gearcase and flush the motor theu thermostat cavity and poppit cavity. Put a gerden hose on the water tube and try to flush it that way. Replace impeller, stainless wear plate and both gaskets. Kits are avail at iboats and ebasicpower and lots of other places. You do not need to replace the upper pump body unless the ss liner is scratched.
terrymason
Thank you for replying. I think that if I'm going to drop the gear case and replace the impeller then I'll go ahead and just replace the entire water pump. Here is my current shopping list:
poppit valve kit
waterpump kit (with impeller)
grease for waterpump
two thermostats & gaskets
Anything else that should be changed out while I'm at it?
Chris1956
Inspect Upper waterpump housing for scratches. If you find them, replace it.
