STATOR ,SWITCHBOX ,TRIGGER OR WHAT
ROTTY
90 HORSE MARINER SER#6572944 17FT SYLVIN DROPING AND PICKING UP CYLS TOP ALL WAS SPARKS GOOD RUN REAL ROUGH CARBS BEEN CLEAN YELLOW STATOR WIRES TO REC. OLD GOT A LITTLE HOT ON REC.BULB PUMPS TIGHT MY BOOK SAYS TO TEST RX100 SCALE ,RX1 SCALE WHAT IS THAT IN OHMS ALSO SWITCH STATOR WIRES ON SWITCH LT BLUES AND REDS STARTED BUT BOX WAS CLICKING SWITCHED BACK
jasonbailey
Re: STATOR ,SWITCHBOX ,TRIGGER OR WHAT
How about some punctuation and proper capitalization?
ROTTY
PROBLEM ANYWAY WHAT YOUR INSIGHT ON WHAT GOING ON HOLLA BACK RED NECK LADDIES IF YOUR OUT THERE I NEED YOUR HELP YOU HELP ME BEFORE
Laddies
Banned
Rotty, have you disconnected the alternator to see if the miss goes away, a bad rectifier can give you a miss like that and will drive ya nuts--Bob
ROTTY
THERES MY BUDDY THATS WHAT YOU TOLD ME LAST TIME AND IT WAS SEEMING TO RUN OK BUT I HOOKED BACK UP WITCH 2 WIRES DO I TAKE OFF THE YELLOW STATOR WIRES HOLLABACK AND THANX LADDIES
Laddies
Banned
Remove the 2 yellow wires, have you tryed the engine with the kill wire diconnected from the box (blk/yellow) to see if there is a short in the wiring harness or the mercury tilt switch is acting up--Bob
ROTTY
I'LL REMOVE THE YELLOW AND GET BACK 20 MIN
ROTTY
OK UNHOOKED 2YELLOW STATOR WIRES FROM REC MIND YOU I DID NOT TRY TO START MOTOR ALL DAY UNHOOKED WIRE SHE WOULD NOT START TRY TRY TRY FINNALY I HOOKED BACK UP YELLOWS AND IT SEEM TO TURN FASTER AND STARTED RIGHT UP NOW ONCE SHE STARTS SHE ALWAYS STARTS BACK SO TOOK YELLOWS BACK OFF SHE STARTED AND RAN ALOT BETTER NO MORE MISSING SO IS MY REC BAD ALSO PLAYED WITH IDLE MIX SCREW IM GOOING TO TRY TO PLANE IT TOMARROW THAT REC COULD CAUSE CLY TO MISS LIKE THAT RIGHT OFF THE BAT I CAN SEE HEATING UP THE STATOR
ROTTY
THEN IT HAPPENS MAN I HOPE SHE DOES GOOD TOMARROW ALSO HOW AN I TELL IF CYL ARE FIREING WHEN I PULL MY PLUGS THEY ALL LOOK USED EXCEPT ONE THE 3RD ONE FROM TOP BUT IT WAS LIKE THAT BEFORE BOAT STILL PLANED AND RAN GOOD LADIES YOU OUT THERE
Rovernaut
ROTTY WHY ARE YOU SHOUTING???????????
Motor Boater Bill
Rotty,<br />Good luck with your problem. Laddies is a great resource and can probably help you with this. <br /><br />It might be useful also for you to know that when you use all capital letters that is generally considered to be shouting on this kind of message board. Doesn't really bother me that much, but some folks are really put off by it and so you might miss out on some additional assistance that you could be getting. Please be aware that I only mention this in the interest of being helpful.<br /><br />Again, good luck!
ROTTY
THANX BILL BUT I KNOW IT JUST LOOKS BETTER sorry THAT WHY I USE IT
