pastorrob1169
Thread starter- Joined
- Jul 13, 2010
- 5
I have a 50hp Merc that I recently replaced everything thing from the fuel tank to the carbs which fixed the bulb collapsing problem I had. The boat was running good. I did not run the boat for about a week and went out and the battery was dead. I replaced the battery and we went out and the boat ran great lots of cruising. I disconnected the terminal when we got back because it was arking when I connected it orignally and was told that something was draining my battery. The next day the boat started great ran fine on the way out with the current at a lower speed. When we were returning against the tide at higher throttle the motor would rev way up (I dont have a tac) but the boat would slow down. When you throttled down it would run ok and we idle back through the canals fine. I did turn around and ran with the current to see if it would do the same thing and it did. Could this be an electrical issue related to something draining the battery or maybe spun prop or even some sort of ignition issue?
Thanks
Thanks
