mustacheyouaquestion
Thread starter- Joined
- Jul 2, 2015
- 38
1993 oceanpro 200:
just bought the motor and trying to get it to fire up.
#5 has no spark and hasn't even attempted to even sputter sputter cranking.
kill and shift test - check
trigger ohm test - check
power pack ohm test - check
new plugs and coil test - check
new fuel and good battery -check
Only thing so far coming under spec is stator.
801 and 803 ...spec is 850-1100
DVA test while cranking was 148 and 153..spec is 150 volts.
is my stator numbers enough to cause a no start as why am I getting no spark to #5?
I did buy a new inline spark checker. When the bulb flashes it doesn't seem particularly bright
