Stator replacement? on 470 on how to..
stonyloam
Do you mean the rotor? Do not try to put it back on with the bolt, you could strip out the hole in the crank, then you would be screwed. If you can not get it off you have two choices, make a proper installer with a bolt (or threaded rod) that will fit and put it back on, then get an alternator kit, or loosen the motor mount so you can jack up the engine high enough to pull the rotor. In the latter case you will also have to pull the outdrive to re-align it, as the chances of getting the motor mounts back EXACTLY the same are slim.
Twistedspeed
Thanks for all the help. Got it out and back in with some help. Not a lot of room to work with. Taking it out today see how she does..
Twistedspeed
Took it out yesterday no problems. Few times the battery drop when I ran the pump but charged right back to 16 on my voltmeter on the boat. Thanks again for all the help.
