bellybuster
Thread starter- Joined
- Jul 3, 2005
- 31
1995 Force 120HP bogs down at high RPM's. Trying to test stator. And I have a couple of questions. Turns out I did not have the right puller so I could not get the flywheel off to look at the part# on the stator. (numbers must be on top) I could not see any #'s on the bottom. My stator has 6 wires coming out of it that I could see. <br /><br />2 yellow<br />1 blue<br />1 blue with white stripe<br />1 red <br />1 red with white stripe<br /><br />The stator is black in color. I keep hearing about a red stator, still not sure if the stator itself is red or the wires are red. The spec sheet I am working from has measurements for OEM (ohms) and CDI (ohms) Whats the differance? My readings are.<br /><br />Blue to blue with white stripe. 6.18K ohms
