Stator question Force 50
tbone123456789
I have a 1987 Force 50 that will not start. I shut it off one day and It would not re-fire. There is crank but no spark. I believe the stator is bad . My stator has 4 wires. The 2 green/yellow wires go to thr rectifier. The 2 blue wires go to a terminal block. When checking resistance the tech manual says to check the Stator wire sets. Are the sets the 2 blue? or 2 Green/yellow? or 1 blue 1 green/yellow?? The manual says I should have 680 -800 ohms if it is a factory Stator or 250-350 ohms if it is a CDI stator. I read open between the 2 blue wires curently and open between all combinations of Blues to Green/yellows. I also read 1.8 ohms between the 2 green/yellow wires. Any help would be appreciated, thanks Tom
