stator problem
gsch59
I have a 1997 evinrude 150 hp feed for tach from stator keeps going out (replaced 2 times) same thing after about 2 weeks Motor runs great except for tach feed any suggestions
Chris1956
Honorary Supreme Mariner
Gee, check the wiring from Voltage Regulator to the tach. Sometimes those wiring harnesses melt and short.
gsch59
Thank's but no voltage new stator wires other wires look good
Chris1956
Does she charge the battery? If so, the tach signal is present.
Just so you know, If the tach wire shorts to ground, the tach will not work, but the VR may still charge the battery.
gsch59
there are two yellow wires from stator just for the tach the voltage goes out on those wires volt meter still works if thats disconnected,
emdsapmgr
Have you tested the continuity of the tach wire from the engine all the way to the control box-to the tach? I had the tach wire go "open" on one of my engines. New tach wire-everything was fixed.
