Stator mystery?
thatone123
Banned
I have a Johnson 15 circa early 80's. I believe the stator is no good and have bought 3 off e-bay and none give any Multi-meter reading or make my test light go on. On or off the engine. I have tested another on a similar engine with the test light and it lights when the 4 probes are tested. Am I testing correctly? What gives...please! Do the 2 coils, the small white one and the one larger green coil tend to both go out at once? I have read this is so.
thatone123
Banned
I can't find the exact year for this motor. Are stators really a mystery as I don't seem to get any replies? The set up under the flywheel seems the same pretty much for quite a few years from what I can tell.
No mystery at all.----Those units are very good and very reliable !----What is your motor doing / not doing that leads you to believe you need another stator ?
thatone123
Banned
No spark! I got it from a guy that said he replaced the coils and CDI so he sold it to me cheap as he did not want to take the flywheel off. I have had a few of these motors and the last one I have lit up a test light or gave a digital multi-meter a reading when the stator was on the motor. Another stator I had once gave a reading when off the motor grounded to the stator plate and a test prong inserted into the 4 small sockets on the wires coming off the stator. I seem to get nothing from these.
Evinrude57
Here are the specs for the stator and what to check. A normal DVM will not check a DVA reading without a DVA adapter.
thatone123
Banned
Thanks, I have this same info. Today I put the neg black lead off my multi-meter into the hole wire socket from the stator. I probed around and got one wire to give a reading. I guess if I did this to begin with I would have known a few things instead of in the dark. One stator set was 400 and the other 300 set on the 20 K resistance setting. At least now I have something to go on. I think it was all in the testing. I'll see where it goes from here and report in.
Evinrude57
Also make sure your using a reliable meter to make your measurements. I would pick up the free harbour freight ones sometimes and had a bunch of them laying around. One day i wanted to see if a newly installed 220V circuit was hot and one of those meters was laying right there so i decided to try it. I was reading 380V, i was a little confused how did my electrician do that? I want to go get my Fluke and turns out it was just the terrible meter i was using. All the Harbour Freight meters ended up in the trash.
thatone123
Banned
But...I know that in the past I have tested some of these OMC 9.9/15 stators with a simple test light with a battery inside and got lit up on all 4 prongs. Today, on closer inspection of the old stators from E-bay, I noticed there were some melted wires and just a piece of worn out crap. They went in the garbage. The last one which is much newer still does nothing and that is hard to figure! E-bay is good for some outboard stuff, but I'm not impressed with un-tested old electric parts from there. These old OMC's which are numerous and really good motors will be facing a shortage of these stators in the future I think as they are not available new.
