stator , flywheel, regulator compatabilities....200hp 2.5L
phatmanmike
hi i have a 1993 200hp 2.5L thats not charging at low rpms, anything below like 1500-2000 rpms, it flutters.
the 200hp has the 40 amp charge system with dual regulators.
i have a parts motor, a 2.0L 150hp with the 16 amp single regulator system.
can i swap the stators from these two and run it with a single regulator if i also use the 16 amp flywheel?
i have a brand new in the box 16 amp stator and a brand new in the box regulator, and i would just use the 2.0L flywheel.
they both use regulators # 194-2579
they both use triggers # 134-6456
they both use switchboxes # 5775
but i would be removing stator # 9610K2 and replacing it with stator # 5860.
sound good? any problems?
studlymandingo
Re: stator , flywheel, regulator compatabilities....200hp 2.5L
From what I have read, it should all interchange, but you know you'll lose some charging capacity.
Laddies
Banned
That will work OK if the stators are the same Diameter I'm not sure but I think some are cast flywheels and some are flex plate and am not sure about the ID of them
