Vandkanten
Thread starter- Joined
- May 21, 2018
- 73
I have an Evinrude 3cyl 35 HP 1998 outboard with no spark.
I have read and seen alot of different test of how to test the stator and in generel test and diagnose your outboard.
Well, it isnt that difficult. But everything gets alot easier if you had spareparts to test with.
Right now I am going to order a new stator for my outboard, but at the same time I thought of a new way to test if my old stator is bad.
Well I have done the ohm and output tests already. I also have tested all other parts.
In my case I am still unsure if it is my stator.
Anyway, my stator test goes like this:
Disconnect the stator totally. And connect from power supply 12V dc and 220V AC to the CDI controller (replacing the stator function). Now cranck and see if you got spark.
If you got spark the stator is bad.
What are your thoughts on this? Can it ie done?
