Re: stater
Well....Grady White Tall Tom....welcome to the forums...we will try to help.<br /><br />If the engine just quit all of a sudden, usually means the ignition system is at fault. The power packs are "generally" the cause. However, the ignition coil under the flywheel can also go out causing the same problems.<br /><br />Another area may be just simply the kill switch or circuit has faulted.<br /><br />If planning to troubleshoot the engine yourself, best advice is to get a service manual. OEM (Original Equipment Manufacturer) is the perferred manual. These can be purchansed through any Johnny/Rude dealer in your area.<br /><br />Or, Generic manuals are also available. Check iboats store for brands and priceing.<br /><br />Or, take the rig to a trusted wrench for the repair.<br /><br />Ya' didn't give us much to go on and this is about as much as we can do for now.<br /><br />Let us know if we can help any further...thanks.
