I have an older model wellcraft with twin 350,s.One would not start so after going by the checks in the repair manual and replacing the coil,impluse sensor in the dist.No start.Disconected the white/green wire from the sensor and it started.The micro switch on the shift mec checks ok. This engine also has a tan/blue wire in the engine harness that is not connected to anything Help.
Oren
Oren
