When I purchased my boat with newly rebuilt Volvo 4.3GS (4 barrel) all I had to do was turn the key and it started immediately from cold. I noticed that once it was fully warm it smoked a little at idle and left black scum on the transom.<br /><br />I purchased the shop manual that said the idle screws starting point is 3/4 turn out and found that mine had been set to 1 1/2 turns. <br /><br />After 10 hours on the new motor I performed a full service and adjusted the carb as per the manual. Now the engine will only start if I use the warm up lever, is this normal and have I been spoiled by my other boat that has a 4 stroke EFI outboard that just starts with no fuss.
