Re: starting probllems
DOn't use starting fluid in a 2 stroke, that is made for 4 stroke engines and has no oil in it an if you run the engine for any length of time on it will be toast.
Not going to beat Joes advice, he has done this for many years, as he said, start with new properly gapped plugs and do a compression check, no compression no start, it is like taking your pulse, it gives you a general idea of the health of the engine.
Is this engine new to you or you know it has run in the past?
