starting problems with 1991 evinrude 150hp 60 deg.
Rola123
made the mistake of letting boat sit for 2yrs with 1/4 tank of gas. Filled tank w/prem gas & OMC fuel system cleaner. motor fired up after few attemps,went to lake, ran great used up 3/4 tank of gas. the next week filled up again & took boat out on 118 deg day. motor died on way back to ramp. motor only runs for 5-10 sec. then dies. will only stay running by squizzing fuel primmer bulb. plugs and fuel filter look :confused: fine. don't know much in trobleshooting. just purchased clymer shop manual. where should i start? can someone with only basic knowledge & shop manual figure this out or do i need a mechanic?<br />any advice/help would be greatly appreciated.
lastout
Re: starting problems with 1991 evinrude 150hp 60 deg.
just a guess, but it kinda sounds like the fuel pump diaphram may have gone. you can find the schematic in clymers and rebuild kits are pretty inexpensive (about $12). best of luck.
